Dabar yra Tre Spa 21, 2026 5:49 pm
Naujos temos kūrimas Atsakyti į temą  [ 5 pranešimai(ų) ]
StandartinėParašytas: Sek Lap 08, 2015 1:18 pm
Vardas: awsdft
SAAB: 9-5 AERO - Saloon
Užsiregistravo: Ket Lap 05, 2015 4:14 pm
Pranešimai: 15
how many people on this site are running stage 3
3.5 bar fuel pressure regulator
3" downpipe - free flow exhaust
open air filter
Stage 3 Remap
295 bhp -220kw :twisted:
StandartinėParašytas: Pir Lap 09, 2015 8:35 am
OT: I don't think, that FPR: 3,5bar is good for daily car. Maybe beter solution is 630cc injectors?
P.S. 220kW@ ? NM 430~450Nm?
StandartinėParašytas: Pir Lap 09, 2015 6:00 pm
Vardas: awsdft
Pranešimai: 15
As I am a member on UKSAABS most 9-5's running stage 3 in the UK are running 3.5bar fpr with NO problems, 630cc injectors is not needed for stage 3.
siemens/green giants only needed for silly big turbo's.
plus 300-310 is complete maximum for std pistons
StandartinėParašytas: Ant Lap 10, 2015 10:21 am
I try to make that stage: intake cobra, maptun IC, intake hoses, 3" down pipe. What power do you think I'll get? I'm thinking about many Nm 8-) ~320-340hp but with stock turbo it is imposible :roll:. If it'll be mater- I have 630cc injectors. I think that 300hp is not a limit with stock pistons.
P.S. its an extreme for the stock fuel pump to work at maximum pressure all time. Its cheaper and simpler version to make stage with 3,5bar FPR.
StandartinėParašytas: Pen Lap 20, 2015 2:37 pm
Vardas: awsdft
Pranešimai: 15
Ok i'll Message the tuner in england that remapped minė, 440nm seems to come to mind.
Maybe 310/315 on stock pistons yes, after that forged ones need to be fitted to stop the engine going BANG.
A stock turbo is about at its limit @ 300bhp after that a hybrid. TD04 19T is the next stage up for the figures you quote 320 -340bhp after that Garrett GT28/30 RS (disco potato) is needed for 350+ bhp
A lot of folks are buying universal frontmount intercoolers for lėss that 100 pounds then the cost of pipework on top
